Can I keep OEM/factory back up camera with aftermarket H/U
it will be hard, i have an avic 120bt and had to get a different camera, but you dont have to get the pioneer camera, any camera with rca will work
Possible? Yes. Probable? Not so much. Anything is possible, but without seeing the ctually camera inputs, i can't really say. But for the labor you would be better of just buying a cheap one with RCA outputs.
You can pull that amplifier and take to an Audio shop and see if they will test it. Most shops charge very little and some will not even charge...
Go 150 Watts speakers or equal to your amps. 150 watts and up is your amps. That's the good rule of thumb.
The best thing you can do is make a solid plan. This way you won't be spending money twice and having to keep going back in add or replace parts.
27
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
664
Shawn1112
Shawn1112
Chicago IL
trumpet
    May 20, 2024
    May 20, 2024
