Can I just replace my crossovers?
Rochambeau
Pudding is good.
Pretty much a relative Noob to Car Audio. I know most of the basics but only get up to date whenever I'm shopping.
Anyhow, my crossovers appear to be failing on a 10 year old set of Boston Z6. I tried to replace them with used ones, but those were problematic as well.
My question is, can I just replace the stock crossovers with a third-party crossover and have them perform as well as the ones Boston designed for this set?
If yes, does anyone have any recommendations? I want good sound quality and will be pushing them with 350 watts per channel, I don't know if that matters for a crossover.
TIA
TIA
get a good head unit that is active network capable. 1000x more superior to any crossover you can find because you get to choose custom crossover points right from the head unit. You'll wire the tweet and mid directly to the amp.
By any chance can anyone else help me out here? I'm really stuck. Is it likely that third-party crossovers will be satisfactory?
Thanks again.
No it wont be satisfactory at all rather garbage actually with those cheap crossovers. list all your head unit and signal processing gear and we'll see what you can do.
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
709
Before I started to cut wiring, I would just leave one of the connectors unplugged. Based on your 3rd image, it looks like the wiring was spliced...
You don't have to but with the exception of what is usually high end car audio companies and home audio drivers it can be hard to find just the...
that will be $40 my btc wallet is 5748384758585854445... jk! :ROFLMAO:
So I did a tone test and found that the tweeters start making sound at about 1500hz which would put the crossover several thousand hertz above...
812
Rochambeau
Pudding is good.
Rochambeau
Kickin it in Cali... Why live anywhere else?
LosIsATool
