Can I bridge this amp to 1 channel??
  • 2
Simon96Taco
Canada
Alpine V12 MRV-F300
It says on it - Alpine 4/3/2 channel power amplifer MRV F300
My roommate says that I can bridge it down to one channelby connecting ch4 (-) to ch1 (+). Does anyone know for sure if this is possible? The guy that I bought it from only bridged 2 of the four channels to run his sub?
I'll be using it to drive a single 10" (SVC) Pioneer sub in a sealed box.
Thanks
Well that *****. How do you know for sure? All I want to run off this thing is the sub. I think if I can only bridge to two channels, I'll only be getting about 60w RMS into the sub.
If I bridge down into 2 channels, can I twist the + and - wires together on each side and then hook them up to the sub? Or is that just stupid? hmm....it sure sounds stupid.
no Problem, thanks very much for your help! 160w RMS for the sub Im' running is not too bad. It's only a low end Pioneer IMPP TS-W254C - spec sheet says it's good for 250w RMS, so 160 is not bad.
Could you link me to the site where you found info for the MRV-F300? Thanks again bro //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
3 ohms speakers are generally what some manufacturers do with factory systems, and wire the components in series. If your amp can do 2 ohm and 4...
If I didn't have my two 4500s already I would probably try the Creampie 7500/ Slapz 8k. :poop:
The question is confusing. Connect the 4" to the radio and use the rear amp channels for the sub. If the sub is DVC you can also use it in stereo...
118
Simon96Taco
Simon96Taco
Canada
Simon96Taco
