well, the sub you have is an SVC sub, so it needs only 1 channel. if it were a DVC sub, the amp would probably work fine because you could bridge the amp to 2 channels and run each channel into the voice coils, but as far as i know, you can't take a 4 channel amp and wire it up to 1 SVC sub, so no, that amp won't work. that is, unless you have 2 subs, if you had 2 subs, the amp would be fine.
