Can a fiberglass enclosure be ported?
peanut packing stuff. helps to get the volume of the enclosure once the box is done.
if not then just split the enclosure with imaginary lines and take your measurements from there.
search "drew wilson fiberglass how-to" i have some super old pictures there of ported fiberglass enclosures being bult
can maybe snap some newer ones of stuff that doesn't **** so much
Well, you'd have to let it dry for a while, but you could always do what you learned back in HS sciences...
Fill that bish with water and then figure out the volume from there.
peanut packing stuff. helps to get the volume of the enclosure once the box is done. if not then just split the enclosure with imaginary lines and take your measurements from there.
If you're going to take the time to fiberglass, why not take the time to get an accurate measurement of the net volume. The packing peanut method is very crude and inaccurate -- using water or another liquid will provide better results. It just takes a little time to cover the inside of the enclosure with trash bags or whatever you want to use, but you end up with more accurate data.
there is a shit loads of ways for you to get the measurements of volume in the enclosure. the peanut packing is very accurate for what is worth. if you want to fill your enclosure with water cool go for it. but the different wont be marginal enough to make a difference.
i have build enough enclosures to know on the design stage what the enclosure volume is going to end up being like.
the peanut package material is the most commonly used and less messy thats why i suggest it.
You can use packing peanuts before you glass which would keep you from finding out after you've gone through a bunch of resin that the box is the wrong size. If you can't get within 0.1 cf in your measurement with packing peanuts then you need to rethink trying to build an enclosure at all.
ace_800
ace_800
Okinawa, Japan
helotaxi
    Jun 20, 2026
    Jun 20, 2026
