can a amp capacitor fu{k up?
Originally posted by FLEX4U18 lol. i just read a thread about how jbl 1200.1 dont put our rms 1200 but max 1200 watts. The reason i want something 800-1200 watts is because i have a crunch amp and it kind of sucks, or maybe its my bandpass bo that makes it ****. i am selling the amp to this girl and now i want something that will thump. You think anyone here is selling a jbl amp in a thread???//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
that guy was very very wrong. did you read my post on that thread??
adam
Originally posted by bumpin_blazer that guy was very very wrong. did you read my post on that thread??
adam
i have a 1 farad cap (1000 watts) can i hook up the jbl 1200 amp to it?. Would that amp be good for 2 kickers comp 12 inch 800 watt max each
Originally posted by FLEX4U18 i have a 1 farad cap (1000 watts) can i hook up the jbl 1200 amp to it?. Would that amp be good for 2 kickers comp 12 inch 800 watt max each
that amp will work with them just be VERY careful with the gain. jbl's are known for being black belt master's of the clipping. i would say ditch the cap though IMHO.
adam
Originally posted by bumpin_blazer that amp will work with them just be VERY careful with the gain. jbl's are known for being black belt master's of the clipping. i would say ditch the cap though IMHO.
adam
are u sure. are u sure the cap wont blow or notthing?
CATALOG # 14F1562 7000 VDC 230 MF ...Measures 25.5 " high X 13.5" wide X 5.5" deep. Weighs in at 100 pounds about $200 shipping is rough though //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Extra alternators optional.
Originally posted by goupinya CATALOG # 14F1562 7000 VDC 230 MF ...Measures 25.5 " high X 13.5" wide X 5.5" deep. Weighs in at 100 pounds about $200 shipping is rough though //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
as if anyone knows what your talking about.
adam
Originally posted by FLEX4U18 is there anyway i can find out if someone's selling a jbl1200.1 amp (used) on this site?
yeah post in the for sale forum my man. i know for a fact someone is he's selling it with his 12w7 but will sell the amp by itself. i say if you have 675 get the package jl 12w7 with 1.75cuft ported box and jbl 1200.1 all for 675 it's a good deal.
adam
Originally posted by bumpin_blazer as if anyone knows what your talking about.
adam
Sorry- didn't mean 2 go over your head there
CATALOG # 14F1562 = a number in a catalog used in reference to item
7000 VDC =seven thousand volts direct current
230 MF =The farad (symbolized F) is the standard unit of capacitance in the International System of Units (SI). Reduced to base SI units, one farad is the equivalent of one second to the fourth power ampere squared per kilogram per meter squared (s4 · A2 · kg-1 · m-
2).When the voltage across a 1 F capacitor changes at a rate of one volt per second (1 V/s), a current flow of 1 A results. A capacitance of 1 F produces 1 V of potential difference for an electric charge of one coulomb (1 C). The farad is an extremely large unit of capacitance. In practice, capacitors with values this large are almost never seen.
25.5 " high X 13.5" wide X 5.5" deep= standard measurements (12 inches = 1 ft.)
Weighs in at 100 pounds= again standard American measurement (16 ozs= 1 lb)
200 dollars= $200.00 standard American currency
In other words this is one BIG cap.
If I could draw... //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
In all honesty, I would steer clear of the JBL 1200.1 amp.
I used to be a big advocate for these amps, until recently. Way too many problems with my own 1200.1, and numerous other issues with several friends JBL's.
Primarily issues with noise introduced into the system by the amp, continuous failing of some of the amplifier internals. - Grounds primarily, but also a good deal more.
I have always felt that the low pass filter on these amps was a joke to begin with. IMO- very difficult to tune, and it can not be defeated to allow an alternate crossover to handle things.
On the up side- they do put out the power they are rated at, dont look half bad, and have an ok bang for the buck factor.
Overall- I would still highly reccomend an alternate choice to the JBL Amps......
The cap issue, well, I'll put it this way. Its hurting more than its helping. I believe we have had numerous discussions on this forum and others that more that support this.
Loose the cap.
take it easy,
-zane
FLEX4U18
FLEX4U18
va
paikiah
michigan born
    May 14, 2026
michigan born
    May 14, 2026
