Calling all ACCORD OWNERS!
Isn't the grommet on the driver's side on or near the master cylinder for the brakes? Upper part of the firewall, you feed it into the car from the engine compartment.
Hmm, I'll have to take a look. I've mainly been focusing on the passenger side, seeing as that's where my battery is located.
This isn't the first time I've ran wire, the previous cars I did it on were 20 years old, so things were much more simple. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Any more suggestions are welcome! Thanks alot guys.
I have the same car and same wire, i Believe there is a rubber surround on the drivers side right above the steering fluid compartment, thats the whole my installer ran the wire for my alarm, I was able to use a smaller wire through first like 8 or 10 gauge, then pushed the 4 guage through the same path and it came through fine, right through the area above the fusebox under the steering wheel. If I get home and its still daylight left i will get some pics and can email you them
I ran the wire from the battery on the pass side above the engine over to the drivers side, and then to the back where the subs are located. There no real place to put it on the pass side, unless you plan on drilling a whole and putting a grommet in the firewall to prevent the wire from being cut. It only takes about 3 extra feet to run it from the pass side to the drivers side give or take a foot
Appreciate all the quick replies. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yeah there is no doubt, Accords are the sh!t. I drive this thing like I stole it and still manage to average about 23-26 mpg, all city driving.
i found a hole on driver side like everyone else is saying. there was a hole there where they ran for my alarm and i just threaded the 4 gauge through it. i have a 94
threw the wire gromet.. that's got to be one of the easyiest cars....
Yep, thats where I ran mine when I had my Accord. I stuck a really long screw driver through an empty space in the gromet, then fed the wire through. Pain in the *** but its worth it.
ls2poweredgoat
Womanizer
ls2poweredgoat
Port St. Lucie FL
ls2poweredgoat
