call me a Ricer but...
The cathode kit on oznium would work for under the dash and seats. http://www.oznium.com/cathode-kitIt's $8 for 2 tubes and the transformer to power them. Thats what I have in my car, cheap and effective.
I would get streetglow for the underbody.
the cathodes are very cost effective and very bright, just make sure you mount them properly. If there's a bend in them, you can crack the inside tube and they'll be worthless.
StreetGlow makes good underbody kits, and if you're interested, PM me, I have a LightStrike kit BNIB for less than you can find them anywhere, including ebay.
I also wouldn't hesitate to buy a FlowLighting kit. Those are Phil's lines, along with the cold cathodes.
thats fine about the flowlighting kit but the underbody from streetglow is way too expensive i can get the one from ledunderbody.com thats way better for way less.
look in the description. They are sold in pairs. The 4" are $8 per pair. The 12" are $10 per pair. You won't be disappointed with the 12".
okay..well its showing me 20 dollars for 2 12" tubes..dont know where your getting that from.
no...you can't
"These amazing kits include two cathode tubes in your choice of colors, and a dual output transformer to make them run like a dream."
read the description. Every 1 you put in your shopping cart is 2 tubes with 1 transformer. So when you put in 2, you were really ordering 4 tubes and 2 transformers.
no...you can't
ahh okay..well I need 4 tubes anyway so that will work.
no...you can't
Thanks
The streetglo kits are pretty sick, my friend has one and it's super bright, he bottomed out and cracked one side though lol.
Thanks
I've been a StreetGlow dealer for over 3 years now and used most of their products. I rolled around with a multi-color kit for about a year and had to replace it 3 times. I beat the hell out of it and could never break tubes though, just had electronic problems. I'll never deal with a multi-color kit again, for me or a customer.
They make the best neons in the business hands down. Their Gold Series is durable as hell and extremely bright. I just installed a LightStrike kit a few months ago and it seems like they learned a lot from the multi-color kit. the LS is really nice, but a little expensive.
is there another place besides oznium or whatever and streetglow..because SG is a little too expensive and I cant order the ones from oznium because the green underbody kit is on backorder and I wanted to order it today.
so basically your taking all the red wires and soldering/heatshrinking them together and then grounding them or the black wires? do you solder/heatshrink all the black wires together also? and then your power source just plugs into the cig lighter? is there a better place I can do that at so I dont have some power source sticking out of my cig lighter..like something I can attach to the side of my middle dash on the side where my shift knob is and stuff?
and one day my cig ligher stopped working out of nowhere could it be just some small wire got disconnected..I dont know how to hook it back together. Any ideas on that also? I appreciate everyones help and thank you.
Check your fuse?
If you're going with the tubes, look at the oznium stuff someone already posted here or I can set you up with some StreetGlow.
already told you a place //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
and im sure you can find interior leds super cheap on ebay
yeah but you never know how durable those things are and how well they will work..and I did check my fuse and replaced it with a new one but it didnt work..
BUT on the diagram on how to wire up the interior tubes it shows a positive wire going through a fuse..do they provide that fuse that its supposed to run through or do I have to buy one or what? im kinda confused..heres the link.
http://www.ledunderbody.com/instructions/new/Single-Color-Expandable-LED-4x15-Interior-Lighting-Kit-Instructions.pdf
ccab
For The Horde!
ccab
Southern Georgia
ccab
