call me a Ricer but...
you prolly blew a fuse,just tap into anything that runs hot with either the car off or on really, and yeah all positives and negatives ran parallel, i have 3 switches though
exterior lights
interior 1
interior 2
i have them all ran off my cig lighter, then ran parallel for each load, 3 different loads = 3 different connection points
If you want an easy access point you can get it from the cig lighter by just cutting the wires and splicing into them like I did, or you can run off of the amp in the back of the car. just put your ground to the chassis somewhere. It's not as difficult as most people think.
I got all the stuff for my cars lighting from http://www.oznium.com
They have super good prices and customer support. A local shop blew my cousins lighting and i asked oznium about it and they replaced all of it for free, even though it was not their fault.
You weren't very specific on what you're wanting to use. Are you wanting to use LED tubes for your wheel wells/under seat/door pockets, or single LEDs, like up in your vents or whatever. the latter is a little more complicated.
If you're going with the tubes, look at the oznium stuff someone already posted here or I can set you up with some StreetGlow. It's really simple installation, just + and -. Put a switch on one side so you can turn them on and off. Everything's wired in parallel, so you take all your + wires and solder them together, then take all your - wires and solder them together.
If you can't do this, you can't do car audio //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I wanted to put 2 15" tubes under each seat and 2 15" tubes under each side of the dash and do a underbody kit. so whatever suggestions you can give me is appreciated.
The cathode kit on oznium would work for under the dash and seats. http://www.oznium.com/cathode-kit
It's $8 for 2 tubes and the transformer to power them. Thats what I have in my car, cheap and effective.
I would get streetglow for the underbody.
ccab
For The Horde!
ccab
Southern Georgia
ccab
