calculating internal volume
actually i can just give the dimensions if that is easier, its 14" tall 32" wide and 16.5" deep. and the port is 2.5" wide and 28.25" long.
Did you fail math in high school or what? Length x Width x Height = Volume
This does not = ft3 though. You have to divide by 1728 then it is cubic feet. Also be sure that if you are measuring on the outside of the wood to take off the thickness of the wood(if it is 3/4" then take off 1.5" for each).
It does if your measurements are in feet dumbass. If you do the multiplications in inches then yes, you need to divide by 1728 because that is 12*12*12, thus converting you from cubic inches to cubic feet.
1) Fill box with water.
2) Drain water into containers.
3) Weigh the water.
4) Convert weight of water to equal amount of gallons.
5) Find the volume of a gallon of water.
6) Multiply the volume of a gallon of water by the amount of water you have.
7) Go shoot yourself because you are an idiot.
the only reason i failed is because i was doing your mom rather than go to class //content.invisioncic.com/y282845/emoticons/bigwave.gif.16324171cad2db62cf4f16568b038478.gif
mmhmm, well enjoy flipping burgers for the rest of your life //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
ha, im the head of R&D department for CTI Industries, its an international company that does high end repair and upgrade work to all types of power plants mostly nuclear power plants but we do work in some coal burning plants and oil burning plants.
CHUCKmfnNORRIS
CHUCKmfnNORRIS
CT
bubbagumper6
