Cadence a7hc fuse
well then where is the fuse holder at rich? cause i dont see one...
It probably came with the amp when it was new.
I have a similar amp (US Acoustics 2300...2x300w, 1x800w @ 4ohms) that also requires an inline fuse holder which the manual states the amp came with, but since I bought it used its long gone.
i guess i have no clue what u are saying, whats "it probably came with the amp when it was new" mean? what are u referring to?.... doesnt there have to be fuses on the amp somewhere? Is there some kinda of other safety mechansim it can use?
You put a fuse holder like this
inline on the power cable, a few inches away from the amp itself.
You can find that kind of fuse holder at any car stereo shop, or online.
well, i have my gain at 3/4 and bass boost at 8-10 and my hu on loud and sub out put all the way up and only then will i get say 800-1000 out of it, but maybe thats because i have a stock 105 amp alt? im thinking of upgrading to a 160 amp alt. Wouldnt this make a big difference? cause maybe im just not feeding it enough juice, i fear sending a clipped signal.
those amps had some shitty preamp sections but when you gave them a 5 volt signal you could get 1300 @ 14 volts..
you can get away with a 125amp fuse..
ther is NO point in fusing twice on the same conductor..
if you do one within 18 inches of the battery its going to protect you wire from starting a fire behind the fuse..
fusing at the amp will add additional ampacity and your wire is sure to catch fire..
if there is no built in fuseing in the amp no need to fuse it.. the only realy reason they recommend external fusing is in case you reverse polarity othwise the fuse @ the battery will do its job...
rosrock
rosrock
saginaw, mi
mclerico83
