cactus pf600.1
Original Poster = OP = You //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
ok what does OP stand for
Nick at incriminator, and carlton both told me that were getting damm near 8600 out of the 40.1's. Scottie and them ran theres at .7, amd i ran mine at .33
correct .707 is the way most determine rms out of peak hold results.
on the cactus it started out at .22 with a rise to .63 thts ohms
Audio Extremes hmmm you say USUCI, but can you even be competitive in that org?
I have had many say usaci isnt competitve, and its a thrid rate org, and this or that org is so much better with better builders, but when they come over and try they arent as skilled as they thought they were lol.
Who were those ppl that came over and didnt do well and what org did they switch from.
Doesn't take away from the fact that you clamped the amp improperly.
Usaci guys are loud for sure, but it tends to be a little bit easier when your "600 watt" amp does 6000. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
First gen s-10 + 3 nice 15's + lots of batteries + bogusly rated amps = 160+
And don't tell me its not as easy as it sounds because I've done nearly a 155 outlaw (unmanned) with one 9515 and 2000 ACTUAL watts.
Its not as easy as it sounds //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
tommy how did i not clamp it properly, and its not as easy as you wanna make it seem at all.
When was the last time you brought a setup to usaci finals, and I only meantion finals because of all the b/s sandbaggin done all year until this event.
How is an amp bogus when its tested at the same test facility as ces uses??????
so this has gone from being about what the amp does to well usaci is an easy org wich I do not see one of you guys a champion of??????
stop the hating the amp did exactly what I said it did!!!!!
You have both meters on peak hold, that's not the proper way to do it.
You want to leave them on continuous and wait till the numbers level off, then record THOSE numbers.
Never been to usaci finals, no shows in my area anyways.
And when I say "bogus ratings", you know exactly what I mean. What serious competition organization would use 4 ohm power ratings? They are completely irrelevant to what the amps actually do, and that's why they are bogus ratings.
It's a game of who can do the least power at 4 ohms while doing the most at .0001 ohms. Usaci needs to get with the times.
You have the meters both on peak hold, that's not the proper way to do it.
its not cheating anymore when everyone does it //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Never said they were cheating, just using a stupid rating system that is completely out of date. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
sanman
sanman
JUNCTION CITY KANSAS
Jeremiah25
    May 31, 2024
    May 24, 2024
