Cactus 7k or Stetsom 7k2d
I say Stetsom. They have stepped up their game with quality and customer service a hell of a lot. I can always get a hold of someone from Stetsom wether it be live via phone, messenger or email.
All your big zenon based boards such as the DD Z2lv and Cactus 7k etc.. No reputable amp repair will repair them if you ever break one. So you're stuck debating on buying a new board direct from MFG or selling blown.
thank you !!!
If you pay enough, someone will repair them. I've repaired two in the last two months or so. Due to subs blowing, and shorting the outputs with the tinsel leads.
And really, smaller != efficient.
SounDigital would simply own the Stetsom and I say this because my friend tried a couple of 4ks and when they crapped out he went back to his RF amps which provided more output and were more stable.
I have personally seen and operated the SD's and they are solid. They are not cheap but its a simple rule where you get what you pay for.
EDIT: And before there are any shots at my friend credibility here is his build log with the RF amps he dropped back in to power his subs.
http://www.caraudio.com/forum/showthread.php?t=383351&highlight=%22big+dave%22
Finally someone else that will back up SounDigital with me lol. Talked to a competitor who told me that the 8kds will drop all the way down to 7.5v without issues. //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
I remember seeing on Termpro that 2 SD 12kds were .1db louder than 3 Stetsom 10kds w/ exact same setup. Also an SD 8kd was 1db louder than a Ground Zero 10k(zenon 7kw board used in Cactus, Atomic, etc).
My next setup will be going with SounDigital amps without a question.
Well, I wouldn't make such a bold statement like that unless I knew what the situation is/was. Frankly, I was a little disappointed to hear that the Stetsoms pooped out on Big Dave.
kylediablo
17 & certified
kylediablo
chatham, il.
sundownz
