Cable size for JBL 1200.1 and RF 300S ?
  • 2
pioneer
hi guys...i need to know what i will need to wire my two amps
a RF Punch 300s for mids rated @ 30 Amps
a JBL 1200.1 for bass rated @ 120 Amps
what size of cables do i need...also fuse sizes
i would fuse it by the battery...then again at the dist block
what stuff do i need ?
thanks alot
hey thanks
but why a circuit breaker and not an ANL fuse ?
will anything happen if use 0 gauge then split it to 4 & 8 ?...besides a bigger hole in my wallet ? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
your going to use a distribution block right??? i recomend a circuit breaker because if u blow the fuses....its cheaper over time....know what i mean?
ohhh ok thanks man
another thing...how to do i wire the speakers to the JBL ?
i kinda confused with the terminals
i wanna use one IDMAX 4 ohm DVC 12
i will run it at 2 ohms
how to do this ?
first off the jbl will have 2 outputs...only use one...that can be a bit confusing....
for a 2ohm load wire as follows
thanks again
what if i were using a pair of dual 2 ohm subs and wantedthe amp to see 2 ohms how will i connect it ?
also...why are the controls on the jbl amps so screwed up ?
having 2 outputs is suppost to make it easier to wire 2 subs........but for 2 dvc 2ohm subs wire as follows for a 2ohm load
No make or model number on it? Do you have an exact picture of the rear and all its glory?
809
https://www.ebay.com/itm/263364485734?mkcid=1&mkrid=711-53200-19255-0&siteid=0&customid=link&campid=5335951755&toolid=20001&mkevt=1
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Oem cables are readily available for most vehicles. Check rockauto. Anything less will be a future headache.
10
pioneer
pioneer
Trinidad & Tobago
MikeofTulsa
    Jun 1, 2024
    May 31, 2024
