Bypass
if i remeber correctly the amp is on the passenger side in the rear. remove the panel in the rear passenger area.
it is not in plain view it is hidden behind the metal subframe.
take the input and output wires out of the amp and use the bypass plug to connect them
good luck
Thanks for all suggestions and all is installed and working great.
13
766
How exactly would I do this for after market amp and since factory is 14 channels how would I get close to the factory amp? I hit a curb on...
Please excuse this extra question .. Is there a specified patch lead or compatible bypass harness for the factory amp or would I have to create it...
862
Your crossover slopes will be steeper ..so sharper cutoff points ..say deck is 24db and amp is 24db youll have a 48db slope the subs will still...
That doesn't make any sense. The directions say to hook it up to the parking brake. The parking brake is engaged when the car is off. You...
17
6K
probe gt
probe gt
Grand Rapids, MI
mustang0969
    May 18, 2024
    May 16, 2024
