Bye-bye hifonics?
qtipextra
The Original
I was bumpin to Get Back by ludacris, and then I noticed my subs looked like they were being pressed out (not a center focal point), but they were still producing sound. So I turned it off, got in my trunk, un-hooked my subs, and checked the coil impedaence to make sure they were ok, and they are fine. Then I hooked up the DMM to my amp to see what the output votage was on a 40hz tone, and its putting out 14.** volts DC with some music. The DMM auto switches between AC and DC, and it was enough DC to switch it to DC mode. I checked my RCA's and they have a nice clean ac signal.
Any suggestions, or is it time to get a new a amp?
You fried one or several output transistors, sending DC current straight to the speaker outputs.New amp time, or you could repair it.Were you running it at one ohm?
I built a box for a customer and installed his system, 2 PBX XS 12's off of a hifonics BX1500D @ 1 ohm and within 30 min. two of the output transistors literally blew up....
OH icee its the output transistor //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif ive had that problem with an old PG i have
Yes, well after bumpin for a nice bit of time, actual resistence was .7 ohms or so. Its strange that the amp gave up now, It hasnt given up all the other times I cranked it. It just decided today was the day.
So how to fix it? How much would that set me back?
A hifonics is a hifonics, I knew yours was a 1000 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif How to fix it?Track down the fried transistors, get the #'s, try and find them and take the old ones out, solder the new ones in.Or you could send it to a place that specializes in amplifier repair, but it'd probably be pricey.Best bet is to find a local place that can do some soldering for ya.
Thanks for the suggestions.
And whoever suggested te viper, no. Now its time for an RE 12.1. Although I have to wait, because I was planning to get one in about a month, not a month early.
I'm not exactly sure where the output transistors are on the BX1000D, but if you can find them I can tell ya how to test em'.
http://www.digi-key.com for the parts, if not there's several others but they have quite the stock.
Hey, just noticed you're from Idaho, cool //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif I'm still adjusting to this state, kinda hard on the allergies though......even the poor cats suffer.I think you're about 2 1/2 hours from me (I'm in twin falls).
Yea, twin falls is 2 1/2 - 3 hours away. Thats cool. When did u move here?
Lol, this has gotten off topic, but oh well. There is another thread that is more in the direrection of help I need anyway.
qtipextra
The Original
qtipextra
Idaho Falls, Idaho
qtipextra
