Buying 2 kicker 03cvr124 subs in a sealed enclosure today
You can build the box yourself. I just do a design, it's not very expensive at all, and all you need is to cut some wood and glue it together. It will make those subs substantially louder for probably the smallest amount of money you could spend to improve the loudness of your system. And we could always design the box to be versatile, leaving you a wide range of subs in that power range that would work in the box, so you could just build it once and keep it for a while.
I worked in a fairly low income area with a shop, and we used to just make ported boxes for prefabs people had bought, it's usually immediately 50% louder, if not more. Just depends on the overall system. Anyways, just some food for thought. Best of luck.
Ok thank you.
MyNameIsHere
CarAudio.com Regular
MyNameIsHere
USA
MyNameIsHere
