Buning smell inside car!!!
innsanes
I run a 12" diamond d9 tdx in a ported box. 2.2 cf tuned to 30hz on a nine.1 at 1 ohm 1200 rms and i recently took it out of the box and added more bracing using lots of gorilla glue. I reinstall my sub in my car today and i have like a wierd plastic burning smell. Its not coming from the amp and i think its either the voicecoil or the glue, but how could it be the glue if it dried already ? I dont think its the voicecoil because it dint do that before the bracing. I'm lost trying to figure this one out. I hope its not sumthin else that is important.
its just the air blowing the glue smell outta the port.
It will eventually go away w/ a little time.
How old are your tdx's and are you slamming it harder now than you did before. I think that its the glue that's used on the voice coil and spider. Mine smelled untill they were broken in. I actually met a guy that would slam his tdx's and clip them till smoke was coming out of ports and they just kept rocking. The next time you smell it for a while turn down your volume and go see if the dustcaps are hot.
innsanes
innsanes
HB Cali
innsanes
Mike Mccabe
