Building Fiberglass enclosure
Atvnut2065
Hey, I've really been looking into building a fiberglass enclosure...sounds good, looks good. Anyway I found a site http://www.fibreglast.com that has all the supplies and stuff but how do I know which ones to buy for a trunk sub enclosure. Also if I am building a fiberglass enclosure for 2 12's what would that be called?
Vinyl Ester/Fiberglass
Polyester/Fiberglass
Epoxy Fiberglass
Please help me out.
Thanks,
Atvnut2065
First you build the enclosure out of MDF, then fiberglass
can be applied to create curved shapes that can be sanded smooth.
You will need fiberglass cloth/mat, resin, hardener, paint brushes, handheld grinder/sander, polyester mold fabric to make shapes, and a respirator. It's not as easy as it seems.
Alright I know I have to make a mold out of MDF first so I do that and then I cover it with fleece and glue and staple it down. After which I proceed to do what??....Also on the web site http://www.fibreglast.com can any one tell me exactly what I Need to buy with names and thicknesses and quantitys.
Thanks,
Anthony:D
Hey I Just wanted to know if this roll of what I believe is veil cloth will help. I bought it off ebay really cheap for 500ft of it. Let me know what this stuff is and if I can use it to make an enclosure. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif :confused: //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
You lay the fiberglass mat on the enclosure, then mix the resin with a I little bit of the hardener. Take a paint brush and paint the resin onto the fiberglass mat, wait for it to dry, continue doing this untill you get it thick enough. Then sand it smooth. I'm sure you could use vail cloth or other matirials but they won't be as strong as fiberglass.
Atvnut2065
Atvnut2065
Mariaville, NY
indosia
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
