Nut Hair Trick
Pubes
2007 F150 Supercrew= limited space for enclosure
This is my first enclosure build and after measuring off all of the dimensions available for this box, I am now ready to start the building process. I have a question on whether to port or not. I am going to put (2) JL 10w1v2 subs in an enclosure that will be 1.329 cuft total. On the spec sheet, it says the sub calls for 0.625 cu. ft per sub SEALED and 1.00 cu. ft. VENTED. Right now I have one of those 10's in a vented Probox at .67 cubic feet, the vent is 4x3in 10 5/8 long. It sounds great running off 350w. The box I'm building now is double that size so I dont see any reason why I shouldnt be able to vent. So, my questions are this....
A) Should I Port? and what kind (circle or square)? How big of a port and length? Finally where should the port be?
B)Should I seperate the chambers?
The box will measure out 51in across. It will be 19inches deep, 7 7/8 in height from floor to seat and 5 1/8 in for the middle height at the center hump to the seat. the box will narrow to a height of 2 inches in the back of the cab. so
51 x 19 x 7 7/8(5 1/8) x 2
Thanks for any help or suggestions.
