building crossovers and other questions
adio
THE STEREOTYPE FIGHTER!!!
ok kids,
i'm in the market for some home mades , so help me out here:
1.) the majority of music i listen to is rap and R&b. if i get some enclosures made i want them tuned to 38 - 40Hz ( i probably won't audibly hear the difference) but 35Hz is the lowest i'm willin to go. i don't know whether to get 6.5, 7 or 8 inch woofers. below, i chose these based on price, sensitivity, freq range and Fs, not necessarily in that order, but i know i didn't wanna go over $55. which ones should i choose? or u can pick something else for me:)
a.) http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=264-852
b.) http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=295-364
c.) http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=295-100
d.) http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=295-310
e.) http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=295-366
2.) which tweeter should i get?
3.) lastly, does anyone here know how to design and build crossovers? i need some. or maybe u can pick some for me from parts express or somewhere else.
p.s. this is for a MTM set-up also.
You want an MTM ?
You should build the Dayton MTM loudspeaker. Roman compiled these designed
from known good designers and he has all the crossover versions shown
here.
http://www.rjbaudio.com/RS180MTM/rs180-rs28-mtm.html
Read the babble and choose which crossover that you think might fit
your needs.
Gets some peg board [thin wood] and mount your crossover parts on it with
tie wraps. Do the parts placement first for easiest wiring, then do the wiring.
http://www.partsexpress.com/projectshowcase/images/surrcross.jpg
You want an MTM ?
here.
your needs.
thanks thy. anyone else
adio
adio
college park, ga
adio
