Building a sub box
screws NO MORE than every 4 inches
closer together than that and your likely to split the wood.
Wimp! Of course my box was only .75cu.ft. but I did about every 2" and predrilled all of em. Didn't need glue after that //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
There was a discussion about this before. The glue is actually doing more work than screws are. I can also tell you from experience ripping a 3/4 MDF box apart myself that the MDF will give out before Liquid Nails will. I'm sure a chemical bond is great, but if you're going to tell me that LN alone won't do it, I won't believe you.
i have a question. You will need 2 different kinds of glue to seal the box correct? One is between the woods, and the silicon is for the outside right (outside meaning Silicon should be at the corner of the L)?
This is sort of correct...
You glue all your pieces together, as well as screw or nail (optional). Thats your first kind of glue. (Wood glue).
Then once the box is mostly constructed, you can 'seal' it with silicone. Usually I try to put the top on last, so I can silicone the INSIDE of the seems. It's alot less messy that way. So on the inside of the L silicone.
I dont know if this is O/T.... but it seems to fit.
My jigsaw is screwy and doesnt cut straight, so I have a hard time cutting the mounting hole....... does anyone know of a store that will cut a nice circle for me? I need it to make a mounting ring for when I fiberglass.... dont want it to be messy so I want it done right. (tried lowes, home depot, neither would do it)
Hades2004
Underworld Master
Hades2004
Canada
LightningStryk7
