building a box for two 10's
vario
digidash hit the gas...
I will have two 10" infinity 1052w woofers. The following is the spec sheet that came from infinity's website. I think I would like to make a ported box because I can make a smaller box and get a lot of bass.
On the second sheet, it shows a sample box design. For two woofers, would I just double that design? Should there be two ports or one? Are there any rules to volume when you have two woofers in the same box? I Know very little about box design and have never designed a box.
Make a box with around 3-3.5ft^3 net volume and tune it to around 30Hz unless you wanna go lower. That picture you showed said 28Hz.
If you need some help with it, just PM me. I can help you out.
ok, so this box is 1x3x1 so it is 3 cu ft. volume. I am not sure how to make the port so that it is tuned for 28-30hz. Right now I just made a slot that is 9 inches long into the box and then 3 inches hooking inwards just as a mockup but I am not sure how to calculate how this slot should be.
yeah, ill also put up some cash in paypal like 5-10 bucks if someone can design me a box that isnt particularly large but has a LOT of bass with these two woofers.
Ok its about 80% complete, so far so good. Ill post pictures when its complete.
Its going to have mismatched 10" woofers //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif till I get some more cash
this box cost me about $70 in materials so far but the thing is tough, I could probably put about 500 lbs on top.
Any tips on upholstering? I am wondering which area to start upholstering first and also where to hide the fold.
Okay, thanks. Im also wondering about the cheapest place to get inset handles, I might just have to cut my own out of mdf b/c I don't want to pay $30 just to add a few handles.
I drive a 99-00 model civic si with the blue paint so its only a matter of time anyway.
Gluing went well, the carpet looks pretty nice, Im gonna remove a couple of the staples after the glue is nice and set tomorrow. Since the box is fairly large I did the ends and then wrapped it longwise with a big piece.
vario
vario
Baltimore, MD
vario
BP1Fanatic
BP1Fanatic
