Build Pix: 4cuft net, 38hz, Solo L7 15
  • 2
tuck05
SLAMMIN ORGASMS
The box is 4.8 Gross cuft, 4 net cuft tuned to 38hz. 3/4" mdf. The box will house an 06 L7 15.
All the cuts are made with a Makita Skillsaw.
I usually draw out the entire box before I cut anything. The lines are there for illustration purposes only. They are a bit skewed once I start cutting b/c of the width of the saw blade.
A few pieces cut.
The first joint.
When copying the image location from photobucket, make sure you copy the "Direct Link" and not the "Email & IM" link, you can then add the [IMG] [/IMG] tags around it
Actually, nvm that, just copy down the IMG link it provides
Edit:
Btw the box looks pretty nice. Did you happen to get it carpeted or anything else?
Edit:
Cody(my lil bro) plans to put carpet on it. He hasn't bought any yet so we haven't carpeted it. Almost every joint lined up perfectly. I was quite surprised since we used a skill saw on all the cuts.
We used a table saw on the box I'm building for my truck. Everything has lined up PERFECTLY so far. Pix of it will be up in a day or two. It is also 4 cuft net tuned to 38hz for a solo 15. I am putting the amp inside the box on the amp rack I made inside the box under a piece of plexi and I plan to put vinyl on the box.
16
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
955
Currently Audison amps 500.1 and 4.300 with kappa 90csx 6x9 component set. Pair of morel 6.5 rear and a single 10” alpine type R.
tuck05
SLAMMIN ORGASMS
tuck05
In The South
tuck05
maylar
    Jun 2, 2024
    Jun 1, 2024
