tagerrung
Hey Guys im getting two RL-i 10 Subwoofers and i was originally planning on getting this sub amp:
Directed Audio A502
Model A502
Max Power Rating 500 watts CEA
Primary Power (power into 4 ohm, all channels driven, 14.4V supply ≤ 1% THD+N) 90W x 2
CEA S/N Ratio (referenced at 1 watt/4 ohm) 70dB
CEA Additional Power (power into X ohm, all channels driven, 14.4V supply ≤ 1% THD+N) 125W x 2 @ 2 ohm
Freq. Range 20-20K Hz
Damping Factor >200
Input Sens. 150mV to 7.5V
Crossover var. 12dB 2-way
Bass EQ Yes 8db
RCA Output Yes, stereo
Protection T,S,D,R
Dimensions - inches
W:10-3/4 H:2-1/2 L:11-3/8
Metric - mm
W:273 H:63.5 L:290
T = Thermal, S = Short Circuit, D = DC offset, R = Reverse polarity, O = Over voltage, L = Under voltage
how does it look? Would you recommend something else?
Directed Audio A502
Model A502
Damping Factor >200
Bass EQ Yes 8db
Protection T,S,D,R
Dimensions - inches
Metric - mm
W:273 H:63.5 L:290
