Budget Sub Amp
tagerrung
Hey Guys im getting two RL-i 10 Subwoofers and i was originally planning on getting this sub amp:
Directed Audio A502
Model A502
Max Power Rating 500 watts CEA
Primary Power (power into 4 ohm, all channels driven, 14.4V supply ≤ 1% THD+N) 90W x 2
CEA S/N Ratio (referenced at 1 watt/4 ohm) 70dB
CEA Additional Power (power into X ohm, all channels driven, 14.4V supply ≤ 1% THD+N) 125W x 2 @ 2 ohm
Freq. Range 20-20K Hz
Damping Factor >200
Input Sens. 150mV to 7.5V
Crossover var. 12dB 2-way
Bass EQ Yes 8db
RCA Output Yes, stereo
Protection T,S,D,R
Dimensions - inches
W:10-3/4 H:2-1/2 L:11-3/8
Metric - mm
W:273 H:63.5 L:290
T = Thermal, S = Short Circuit, D = DC offset, R = Reverse polarity, O = Over voltage, L = Under voltage
how does it look? Would you recommend something else?
yeah that 8002 will do the trick. zfactor is also selling a pg xenon 600.1 here for about the same price, it will also put out around 840 watts.
wait, but those are only 200 Watt at 4 OHM and i wanted 300-400 Watt at 4 OHM right? Also, some guy told me that with these subs i should "Buy the dual 4ohm vc configuration, get an amplifier that’s 1 ohm stable" So yea. Should i get the Orion 1200D?
You're getting good advice.
You want something that does its maximum power at one ohm, so look at that spec before buying.
so do you think i shouldnt get the Orion 8002 then? because it says RMS is unstable at 1 OHM
then i guess i will go with the 1200 D amp because it has max watt at 1 OHM, hold on im gonna go look at its other specs
Lanzar 1200d...........bad *** budget amp, does rated power nicely....... there's one for like 120 on the classified iirc......best budget amp in that price range IMO
i miss my old 1200d
tagerrung
tagerrung
Los Angeles, CA
Ali1
