audioholic
not a moderator
A car will run off the alternator alone, once the battery starts the engine.
You are both right, sort of. The alt is there to supply current to replenish the battery, but the battery does not regulate voltage if/when the alternator exceeds the batts voltage. The system sees the higher voltage from the alt.
Upgrading a battery reduces resistance in the circuit. Additional batteries are indeed only for extending engine-off playing time.
