bridging my system
If its 1 ohm stable, wire them both in parallel to get 1 ohm. You really need to get a bigger amp those p3's are going to be way underpowered! You should be running at least 800 a piece!
I have 2 12" rockford P3S 4 ohm subs and a hifonics zues 800watt rms max amp. Is it possible to bridge both of my subs to this amp without messing anything up and if so what would be the best way to do so. Thanks.
DVC 4ohm subs?Or SVC 4ohm subs?
P3 Slim models are rated 400 RMS each and are DVC so you'll be powering it just right if you wire it all in parallel.
That amp does not have the RCA summing feature. You will have to use RCA splitters at the amp. If you already have that, then check the gains.
967
Bridging the amplifier Mono(LPF)on that sub will work just fine @4ohms
421
dcpvnlb1
dcpvnlb1
Evansville, IN
Tenacious
    May 12, 2024
Brendon Jenness
    May 11, 2024
