lebaron87
i have a 760 watt pioneer amp. what is bridging exactly and can i bridge my amp without it hurting anything
Originally posted by CarAudioAddict Bridging an amp is when you use both channels to drive one speaker.
Many amps are bridgable either by changing a switch setting or by the way you wire the speaker to the amp. There are also devices you can get to bridge a non-bridgable amplifier or bridge 2-mono amps into one.
In general bridging an amplifier won't do any harm. Just make sure your speakers can handle the extra power
This next part gets a little, very little, technical. In order to understand you must know what the music signal is like traveling through a wire, and how amplifiers work
All amplifier bridging does is invert one of the channels (more explanation later). Now when one channel is pulled to the positive, the other is pulled to the negative. This in effect will double the voltage and amperage through the voice coil. In a 100% efficient amplifier this would result in a quadrupling of amplifier power(compared to one channel). In most cases though you only end up with doubling the power.
To invert a channel, you are basically reversing the polarity of the positive and negative rails for that channel (it's actually more than that, the actually signal is changed). Now when the signal is supposed to be positive, it is actually negative.
I'm not sure if that is very clear, but I have always had trouble converting to lay-men's terms. If someone else wants they can try.
