Bridging Amplifiers...
truthin07
This may sound like a amature question, but i was curious of how the whole bridging amps work... i have an amp that is bridgable (1x1300watts) i was wondering if i bridged 2 subs to this amp, how many watts would go to each sub, does it split, 650/650 or what?...I have a 2000watt Pyle amp and 2-dual 2ohm 12" CVR Kickers.
any help would be greatly appreciated.
If at bridged it's 1x1300 RMS, then yes it's 650x650
What you also have to check is the ohms of your subs and amp. So check the ohms of your amp when bridged and see if it'll match up with your subs ohms, if it doesn't than you can't do it. [unless you want broken gear]
truthin07
truthin07
Nashvill, TN
n2audio
Mike Mccabe
