Bridging amp question
tractng
Guys,
I have a Phoenix gold amp R5.04
I want to bridge the channels to power my front components.
Since I am bridging it, do I still leave all 2 pairs of rca interconnect intact or do I remove one pair?
Also, there is a switch of 4 channel and 2 channel. I am assuming I will need to switch to the 2 channel mode?
Thanks a lot.
Tony
You can easily test things out by removing an input to the amp while the amp is playing. in a bridged configuration the amp will work with only one of the two channels receiving a signal, but the issue is that the second channel would not contribute anything and would just serve to reduce performance.
thus if you plugged the same signal into, say channel 1 & 2 and played some music/tones, you would notice a drop in volume if you were to suddenly pull the signal from channel 2.
so if you really want answers, you could just try it out.
tractng
tractng
Los Angeles
thch
