bridging amp - need help with rca cables
thaster
pennsylvania
hey i am trying to bridge my Diamond 4 channel amp to achieve 175x2 @ 4 ohm for my Crystal components. However i do not know how many rca cables i should use, where to hook them and what setting to use for the amp (2CH, 3CH, 4 CH). Should i use 2 sets of RCA for the front and rear and set the amp at 4CH?
Doesn't your manual give you the wiring instructions with diagrams? I put a Diamond amp in my buddy's tahoe, and it had illustrations. You need one set of RCA's PER COMPONENT. If you are running a 4 channel amp bridged to two channels, then you need 2 sets of 2 channel RCA's.
Audio Systems
That amp does not have the RCA summing feature. You will have to use RCA splitters at the amp. If you already have that, then check the gains.
978
Bridging the amplifier Mono(LPF)on that sub will work just fine @4ohms
290
  • Locked
583
thaster
thaster
pennsylvania
1hawaii50
    May 24, 2024
    May 23, 2024
