Brain overload, am I making this to difficult?
Thanks for the help guys. Ive never set one that way, but rea up on how to, and found the calculator that was under the sticky tread. I'll be able to figure it out. I've always run just one sub, never ran 2 before so that's what's throwing me off. I assume parallel is run like this
http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2SVC_4-ohm_mono.jpg and in wiring like this both subs will have 2 ohms resistance so I need to find an amp that runs around 1000 watts rms with 2 ohms resistance.
You really want to re phrase that.In a circuit like this we assume impedance = resistance and V=IR where V is voltage, I is current, and R is total resistance. P=IV where P is power, V is voltage and I is current.
For wiring in series: Rtotal = R1 + R2 + R3 .... etc
For wiring in parallel: Rtotal = 1/((1/R1)+(1/R2)+(1/R3).....etc)
And in parallel OR series, the subs will be getting the same power, as long as the voice coils are wired the same on each sub.
In reality none of these will be exactly correct for the AC circuits we are running BUT they are a close approximation without many more very complicated formulas and experimentation.
So what was your point.
My point was to elaborate on and explain your point, that's all //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
In a parallel circuit, the voltage stays the same throughout the branches, so the amp is set to 44v, both speakers are going to receive 44v. Assuming he wants 500 watts for each subs.
The Amp
44.72135954999579v=2ohms*22.3606797749979a
999.9999999999998w=22.3606797749979a*44.72135954999579v
The Subs
44.72135954999579v=4ohms*11.18033988749895a - each
500w=44.72135954999579v*11.18033988749895a - each
so 11.18033988749895a*2=22.3606797749979a, 500w*2=1000w
That's what I meant when I said in a parallel circuit the voltage stays the same and the current adds up.
NismoV240
NismoV240
Charlotte, NC
SuperSaeYoung
