Bracing Sub Enclosure
seedlings
This has surely been addressed, but the search function has been giving me this error for the last couple of days:
connection to localhost:9312 failed (errno=111, msg=Connection refused)
I'm working on a sub enclosure. The inside wall is going to be fiberglass to conform to the side of the cargo area (starting on that part after work today). I need advice on a few things:
1) should the sub face up or to the side? Up seems best to add bracing.
2) how much clearance does the 6" flared port need? If it faces the rear, there's only an inch.
3) RED is what I was thinking for bracing. I'll have additional bracing wherever the sub is mounted, plus a double-thick baffle.
Sub is a SoundQubed 215, amp is Alpine MRP-m500
Thanks!
CHAD
seedlings
seedlings
Saint Joseph, MO
seedlings
Mike Mccabe
