Box wont hold up?
mrjoeyjiffy
I have a fairly large box tuned to about 29hz for my 2 JBL Gti's(12 inch). The port is in the middle, and it is double baffled. I noticed a couple weeks after i got my new amp my subs were sounding very "muddy" and didnt have near the intensity they did before.
So i checked on the back of the box and noticed that 2 screw heads were out, i pulled them out by hand and they were broke in half! Keep in mind these are 1 3/4 coarse thread drywall screws that were pre-drilled with a counter sink bit as to make sure the mdf didnt split.
Since then I just havent had the bass up at all, and i can not really afford to have someone build me a new box, and I dont really have the proper tools to do it myself at this point. So I grabbed some bondo from work and made a layer across the seem of the back of the box let it dry and tried it out again, about 3 seconds of awesome sounding bass then it went right back to sounding muddy, as it turns out the bondo popped off right at the seam across the back of the box.
SO my question is, is there any relatively cheap way i can reinforce the back of my box so this does not keep happening?
if you think you have enough glue, use more. use a good strong glue also. i like Elmers ProBond, but most on here use TiteBond II or III
also use some bracing of some sort, some threaded rod or some 2x2 or something along those lines. as mentioned above L brackets in the corners should help too
So i took the back off the box, to find there was no wood glue, i called the guy who built the box (otherwise it was a hell of a job) and hes like " I told you i didnt glue the back in, just put the screws cuz i figured youd take the back off to mount the subs"
so 5 of the 10 screws were snapped in half, got those out, lined the whole back with wood glue and filled in the screw holes with wood glue and screwed new screws in, ill give it some stress testing tomorrow and let you know how it goes, thanks to all for your input.
That shit SUCKS balls, will never use it again as it doesn't hold well...
it works fine if you wet the 2 surfaces to be glued together. it does **** however. it is not stronger than wood glue, so there is really no point in using it. gorilla does make wood glue, but i've never tried it.
mrjoeyjiffy
mrjoeyjiffy
Duuuuuuval
rumblebee2
