box tuning help afte box is built
I don't think I have space to make the port longer externally and can I make the port thinner and then make it longer inside? I kno it will be trouble taking the box apart but if it will work ill do it. And can you help me figure out on tuning it because I'm a pretty big noob at this
making the port thinner will only increase air speeds and cause port noise, which no one wants.
I can't help much, I'm almost finished my first box design and I'm still making sure it works before I go ahead and build it. What I've told you so far is based on research which I'm sure you can do as well. Have a look at my join date, I've only just got into car audio.
Try figuring out what you're doing next time. If you can't add more length to the port outside adding length inside will be terribly difficult and further subtract from your internal volume. Nothing you can do to this box beyond sealing it will help.
What it I take the port out and make an Aero port?
TexMexThugga
TexMexThugga
Mcallen, TX
TexMexThugga
NorthFramingham
    Jun 30, 2026
