Box Size
  • 2
if thats the interior dimensions that would be about 2.8 cubic foot or 1.4 per sub if thats the exterior dimensions and its made of 3/4 wood that would be 2.05 total or about 1 foot per sub. whats yer subs recomend??
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
3K
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
40-85l is about the size range most high powered 12" woofers will want for a box. You should use manufacturer suggested box specs unless someone...
I would like to a bandpass box wherein the subs are facing each other and each have their own sealed enclosure with the center section being the...
Try the sealed then. If you feel you're lacking low end extension you might try to build a ported box to give you a little more output down low.
7
TRAVIESO
TRAVIESO
CA
geonn
saints747
    May 7, 2024
saints747
    May 7, 2024
Latest topics
