Plutoman
<-- Yes, that's me.
So I have a single IB 10" sub. Infinity Perfect 10.1.
About 200 watts to play around with. It sounds good musically as is - but I'm stuck at home sick for now, and I've been curious to do this for a while.
I'm looking to build the most efficient enclosure system with a single low powered sub, just to show it off to people, and show how much of a difference the enclosure makes.
I'm interested in potentially a 6th order bandpass through the rear deck, or a 4th order. I'm looking at nailing the lows particularly well, to also show that you don't need a big sub to get down there.
I have access to wood, and a LOT of PVC pipe. My dad's a plumber. So anything from half an inch all the way to 6, 8 inch pipe, is easily obtainable.
Suggestions as to sizing, tuning, what would be most efficient design to go for here?
Sub specs.
Qts - .42
Qms - 8.83
Qes - .441
Fs - 28.35hz
Vas - 1.134 ft^3
Xmax - .54 inches (13.7mm)
Sd - 53.63 in^2
Rated for 350 watts.
Sub specs.
Qts - .42
Qms - 8.83
Qes - .441
Fs - 28.35hz
Vas - 1.134 ft^3
Sd - 53.63 in^2
