Box Request
Bobby322
1. Car. Year, Make, Model:
2004 Dodge Ram 1500
2. Subs. Make, Model, Size, How many:
(1) Audiopulse Axis 12''
3. Power. How much power per sub:
~2500w
4. Goal. SPL or SQ:
SPL but want it to sound clean and low as hell
5. Sealed or ported:
ported
6. Sub/port placement:
sub/port up
7. Max dimensions:
I have about 14'' of width to worth with. I will have more if its possible to build around a 2''+ hump that stick out in the back wall. Window line is about 24''. Have about 5ft of the length of the cab to work with.
8. Desired NET vol and tuning(optional):
2 cubes @ 28hz. 4'' port diameter, 15'' port length.
9. Finish:
Double baffle, Flush mount
45s in corners
kerfed port
paint, rhino lining, or carpet (depending on price)
10. Zip code for shipping:
76063
11) Additional comments:
The shorter the box is, the better because that will leave me with more leg room. I'd like to make it around 12-13'' wide (just enough for the sub), and go with a lengthier box. PM me a price quote and I'll see if I can do it. I also may just want a cut sheet.
Yeah I've had a few similar boxes build and they're like 13'', but I'm not sure the flush mount would work since part of that 13'' or so are the front and back pieces.
Bobby322
Bobby322
TX
Bobby322
