Box recommendations? 12'' Type R
I just had the same issue with the box. I went from a 1.5 net tuned to 30hz to a 2.3 net tuned to 32. I was way too boomy for the lows and I like hip hop. The rolloff went down pretty quick so If you like to listen a little lower volume sometimes, you might not like it.
Its almost like listening to tweets with a sub, no midbass. My 1.5 net was punchy and all music sounded good with it, not quite as low but still hit pretty good for lows.
Now, I bought the X, cuz this was why I designed my box bigger. In the box with the X, its about 2.15 net due to sub displacement and port displacement. It sounds alot better music wise and is a hell of alot lower than the R. Now Im happy.
ok, i'm dismissing the 3 cuft at 32hz from the carforum site.
from all the replies i think i'll go with a 2 cuft at 32.
i dont like boosting my music up, so the car next to me can listen to it.
what i like is that bass nobody knows where its coming from and you and whoever is in the car can feel it in the chest.
this is what im making:
its 4 cuft total, but the plan says 2cf. weird. i'm making it for a re se. can someone clarify?
if you take the measurements into the re enclosure calculator, it ends up giving you a 2cf tuned at 30 hz box.
i finished building my box. it came out pretty good. it's a 2 cuft tuned at 33hz. i get more low end bass than before, but the higher frequencies have softened quite a bit. i have to cranck the volume the get them going.
what should i do next?
i finished building my box. it came out pretty good. it's a 2 cuft tuned at 33hz. i get more low end bass than before, but the higher frequencies have softened quite a bit. i have to cranck the volume the get them going.what should i do next?
You should probably crank all bass settings on the headunit and amp as well as the gain. Oh, and don't forget to add bass boost for extra dB'z //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
A lot of low tuned boxes drop off with higher frequencies, its not uncommon. It is more of a function of the specific subwoofer and enclosure though. You can try to find a different sub that will work better or beef up your midbasses. Other option is not to tune so low, which obviously has its downfalls as well.
2cuft total? and you were running an mrp-m500 and type r 12?
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
No sense in arguing, the software has helped me do just that, many, many times. A smaller box can be tuned to the same lower frequency in this...
20
From their website. Sealed: 0.8 – 1.1 cubes Ported: 1.75 – 2.1 cubes ported after displacement, 29-33hz tuning Sub Outside Diameter 12.500" Cut...
317
647
dewbie
dewbie
Seattle, WA
pbasura
Brendon Jenness
    May 8, 2024
    May 8, 2024
