Box plans for 2 12" RE SE's needed
gearhound17
I have 2 12" RE SE's and I want to build a ported box for my Tacoma extra cab.
Powered by a Sundown Sae1200d.
From what I have researched it should be 4 cu ft tuned to 33 hz and around 64 sq in of port.
I think I want sub up/port up or maybe sub front/port up.
Am looking for a dual port configuration either on the ends or in the middle.
Max dims are 49 w x 12 h x 16 d. Might be able to add a bit to the height.
Would like to see a sample of what it looks like. Also would like cut sheet.
I have something I might use from RE's sight but looking to see what other designs are available.
Let me know what you have and price.
you wont have enough volume with those dimentions, the box gross volume is 4.2 cu ft. ya still need room for subs and port. you could get away with 3.6 cu ft net and perhaps a tuning of 35Hz. i would go with a 4" wide port 14.5" tall. please let us know your MAX dimensions
i believe he said those are his max dims!
I have 2 12" RE SE's and I want to build a ported box for my Tacoma extra cab.Powered by a Sundown Sae1200d.
no he can add 2 height
I could probably go 49 x 16 x 16.
I get a larger dimension from RFs site as opposed to RE.
If I go 14 h x 49 w x 16 d on RF's site I get 4.98 cu ft.
And isnt sub displacement .07 for each sub?
sub displacement is .15 each, on REs site i came up with a 3.9 cu ft tuned to 35. ive factored for sub diplacement, values are as follows
49
16
14
14
.75
4
11
enter all that shit in and youll get what i got
gearhound17
gearhound17
next door to you
GAM3OVR
michigan born
    May 14, 2026
michigan born
    May 14, 2026
