graffix989
this is the top view for two AW1206T Audiobans. going for 2.5 cu. ft. / port 4x7.25 per sub...
the only thing i didnt quite understand was the port depth... how far should the walls of the ports go into the box. i guessed it would be the same width as the port opening on the outside. i also rounded off a couple numbers, the box should be just under 5 cu ft. ie 4.9 sumthin.. thats all my trunk will allow... would this work ok?? im shooting for about 36hz.. any suggestions would be great..
the only reason i went with this style vs. the generic (subs right next to each other with the port to the side) was the structural integrety... i figured this would have more support in the middle than the other setup. but am i losing sound quality??
