Box help, 2 12w6s ported
zbryant4210
PVB
currently i have a 2.5 sealed enclosure for my 2 12w6s and it just does not get as loud as i want. i was looking to upgrade to a ported box. i was looking for anyone to help me design a box, or just throw out some numbers of what i should build around. Like how big, what tunning and such.
thanks
also would running 2 diff subs in the trunk, 2 12w6s and 2 12w3s be a bad idea
edit: was told to only run 1 set of woofers, so the 12w3s with the slash 500/1v2 amp is for sale
thanks
2 different subs in one trunk is not recommended
what do you want to get from this setup? spl, sq?
JL recommends 1.5cuft@32hz, but that gives you a peak at 50hz
I would say to get loud and lower bass, go for 3 cubes @ 30hz (moves the peak from 50 down to mid 30's)
and these are per sub numbers
thanks dman, what size/kind of port and how would i go about porting it. Does it matter where the port is.
I have always used slot port boxes. the slot can be anywhere on/in the enclosure, as long as it has room to breath both inside and outside the enclosure. The size of the port will change with volume and tuning of the enclosure.
edit: you could also use aero ports, but I know nothing about them
zbryant4210
zbryant4210
PVB
psych0ticnemes1
BP1Fanatic
BP1Fanatic
