Box for2 jl 10w3v3
rickvl
What box size is good for 2 jl audio 10w3v3-4 ohms and which is better sealed or ported?My amp is a Alpine MRP-M850 800 watts RMS x 1 at 2 ohms, I will be wiring them to 2 ohms.I listen to classic rock/heavy metal. It's going in a 92 honda civic hatchback,so not alot of room in the hatch.
Thanks
for what you need just get a sealed prefab 2 10 box with around 1.2-1.5 cubes of airspace
since your not going for spl going with a port would just be overkill and sealed boxes are better for sq any way
just google it and you should be able to come up with something
for what you need just get a sealed prefab 2 10 box with around 1.2-1.5 cubes of airspacesince your not going for spl going with a port would just be overkill and sealed boxes are better for sq any way
If I wanted to try a ported box whats the best size?
if doing a ported is is usually best to build it, as it is usually hard to find one that is tuned to what you need for what your doing. you need a box with 2.25 cubes and a port tuned to 32. you can usually find someone on here to design the box. im not good at doing that so i usually dont try it for anyone. i saw a post on here not to long ago that someone was designing them to test out some new software, not sure if thats still going, but im a design wouldnt be all that hard to come up with
Do you recommend the same size ported box for the 10W6V2? I just aquired one as the price was to good to turn down
Thanks.
rickvl
rickvl
Vancouver,B.C.,Canada
Cruzer
