box for re 12 xxx
marcin93
are the box specs or re's site really going to give me what i want?? (2.2 cu @ 34 hz)
Im tryin to get a sql set up that is leaning a little bit more towards spl, suttin that will get some nice numbers but still bump to techno and but a smile on my face. Ideas? This will be in a trunk and powered by a soundstream rubicon 2500d.
ive never used the subs, but from what ive read they like big boxes and alot of power, so id up the airspace if i were u. If you call or email RE i bet theyll tell you the same thing. this guys running less power but 2.7 sealed
[video=youtube;0Zbo-Ypx7Pw]
see and now im lost lol. one person is saying that 2.5 cubes is good and then someone else is telling me big boxes.there is a big difference between 2.5 cubes and 4....
are u giving it 2500 or 1700?
if ur giving it over its rated power, going too large can possibly cause problems.
if ur giving it 1700, then 3 cubes should be fine
yes, which is why i said if he is sending over rms to the sub, it can cause problems? can u read?
i was just clarifying it for him bro. dont get butthurt //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
nothing to clarify though? its not like the sub can wire to 1 ohm, and 2 ohm without changing the coils
i'm not talking about that...you said if you give the sub over it's rated power and stick it in a box that's larger than the rec. box size is you can experience problems. i was just makin sure he realized what those problems were. too many people take advice without actually knowing "why"
The sub has a very low fs. If you're going to port it, you are going to have to tune very low, unless you want to have a big peak in the response. I wouldn't even think about tuning above 30hz with it, unless you're looking for a big spike in output in the 35-50hz area.
fair enough
marcin93
marcin93
United States
Audiohazzard
