Box for four tens.
there it is, like i said, i got a little carried away
the dimension have changed" the box will be 15X20.5X35.5, that makes the box 5.04 cubes, then with the displacement of the port and the subs it will be 4.05, then i figure bracing will take up a little more, but not to much, so what do you think of this box then, any flaws?
shyte! really? y didnt anybody tell me earlier? i dont think i can fit them all on the top
here is the refined version of that, in multiveiw projection form:
so it will be a big problem if i put them on the different planes? ill check out putting them all on top, will it sound ok, or would rear facing be ideal?
You can do 2 on the front right corner and 2 on the top right bottom corner.
You could also do 2 firing forward and 2 firing to the right... or 2 right and 2 up... so long as you try to keep the subs in that corner, and keep the port entry in the opposite corner.
If you do all 4 subs on top, do the port across the bottom - which more than likely isn't feasable.
Fire them all in the same direction, it doesnt have to be up...
Is this thing going to fit through the trunk opening?
i dont have room to face them any way but up
ium pretty sure it will ... you better believ ill triple check it though,
brandontw
just some guy
brandontw
Reno, NV
brandontw
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
