box for 2 SDC2.5-12
be sure to add bracing and maybe even consider a double baffle. But to answer your question yes.
Note-I did not do that math on your design, but if your is correct it will be fine.
its off the free box plans on forum, but thats not gonna work just remeasured and ill be all the way up with no leg room
Those specs should work fine, but you'll want something not so deep(assuming you're not a midget). With a 12" sub you can fire up and make it 13" deep. Or you can fire subs forward and port up and go even shallower if you really need leg room. What kind of dimensions do you have to work with?
35, 15, 15, a little leway, i just want to have some leanback room and leg room
for the extra money would 2 be worth it vs 1 12?
I believe so. You'll have more output because you'll have more cone area and less power compression as well. I assume you'd be running the amp at 2ohms to a single 12"er, which would be more power than you'd really need for a single 12" SDC. Use the amp at 1ohm and you have more power overall, more cone area, and better use of that power by having less power available per woofer, while still being able to push them hard.
very true...You should have a good deal more 36" wide though. I talked to my friend, but he removed the lower half of his plastics for enclosure space. He runs 3 15s forward and port up.
SpedBoy
SpedBoy
Brighton, Mi
RAM_Designs
