box for 2 hds212's opinion ??
Picking up a couple hds212's and I came up with a box that will seal up and fire forward in mustang. It's 34" wide x 27" deep x 13.5" tall. Will be 4.5 cuft net @ 38hz with 73 sq.in port area. So 16" per cube. What you guys think ? Will be powered off a saz1200d @ .5
A little high on the port per and small on the net cubes (2.5 per is ideal) but yeah that will work on that much power. I've done a lot of boxes for my Mustang and rear firing 7" from the tail lights gives me the best results. I did a forward fire sealed up and lost dB big time.
the subs model flattest on winisd with 4-5 cubic feet at 32 hz. The subs dont need that much port area since xmax is low, minimum port area is 26 sq inches of port area per 12.
If I cut back on port area I might could get closer to 2.5 per, I read dd and Sq like big box big port, that's why I shot high on the area. What would you suggest on the port ? I figured forward sealed would be the way to go.
Ok, so we're looking at 52 Sq minimum how do I know what is optimal ? Is that where the trial and error comes in to play ?
TwistedOracle
OK
Jeffdachef
