Box Designers.. Make some money?
RADEoN
jejejejejejejejejejejeje
I'm in dire need of some help here. The person who helps best will get paypalled 10-15 dollars USD.
I need to fit 3 ported W10GTi's in a box that's 31.5x15x21.
It needs to be a low tune. Preferably around 30-35.
I'm not concerned if the SLOT ONLY port is on the back.
Could I use polyfill for this application?
http://manuals.harman.com/JBL/CAR/Boxes%20and%20Parameters/W10GTi_rev_f.pdf
By the way, I don't mind inversely mounting. Although, If i were to invert, I'd have to lose around 5 inches off of the depth. and I'd have to invert all 3 because i'm running 3 subs off of 2 amps.
if you built a single chambered box to those dimensions with 2 4" precision ports from partsexpress and use their full length, youll come up with something in the area of 3.95 cubes @ 30hz. Its not really enough port area, and its a bit small, but you cant do too much better. I dont have BB6p on this computer so i really cant see what a box like that would do.
..... well if you are in a car with a trunk -- these subs don't look so bad for an IB setup //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif -- you will end up with about a .6 qtc from just looking at it -- plenty of xmax -- stiff enough suspension to keep xmech from being ran into too ez... -- these aren't subs to be looking to use in a ported box IMHO -- but if you wish... you can pull off a ported alignment -- it is a bit tight though...
Those subs ARE to be looking for ported if thats what he wants..one of those subs is mine //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Single 10" I was running in 1.75 tuned at 27 (Moe Lester built the enclosure)...does VERY well in that box but since its 3 Kevin doesnt have much room....
I *might* be able to help design the box cuz I can use Autodesk Inventor Prof. 10 at my P.O.E. class so if Moe comes up with dimensions or w/e or you can give me a design and I can make it with free time during class....
RADEoN
RADEoN
Pennyslvania
negativezeroz
michigan born
    May 14, 2026
michigan born
    May 14, 2026
