Box design programs and rendering
AcidicDreams
I don't need one of these
What program is used to create box printouts with dimensioning, and possibly 3d rendering? I used to use AutoCad but I forgot how, I can't even figure out how to set a dim....
in anycase I'd just like to use a quick and easy prog because I'm going to have someone do the cutting and assembly work for me on my box so I don't have to but $130 worth of tools...
I have used Sketchup and Autodesk Inventor. Inventor is an awesome program, personally I prefer it over Sketchup.
hmm sounds good... I loved autocad (was using it in 1999) but the new ones got me stumped... I'll try inventor
Inventor is amazing compared to CAD!!!! Its unreal, takes a little getting used to though. Basically you have multiple sketches and you can draw out the side of the part, then dimension and alter dimensions in any sketch at any time. Then you can extrude, revolve, shell, theres just tons of stuff to do in this program. Theres even a part library with tons of parts for use when creating working assemblies. Just read through some of the tutorials and you'll figure it out. Its not that hard of a program to use at all. Good luck! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
argg... I already have autocad 2004 laying around, I make a square, make dimensions but can't figure out how to edit them so it resizes the box... it's sooooo basic too.. argg
Yeah with CAD you can't go back and edit dimensions like in Inventor, you just gotta delete em //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
huh, I remember doing this, but it was old school cad so it must be inventor that I need... argg...
do you know how to set a legth of a line segment in cad...???
Yeah there a couple different ways to do it, I haven't even messed with CAD in a while lol, but you can use polar and just set the angle in the settings for polar, then type in the value when you are creating a line. The other way is to just punch in the points in the command line, type l or line then the points where you want it at. Polar is much easier, but Inventor is awesome. It is such an amazing program, Sketchup is sweet too, but I prefer the layout of Inventor better. Not to mention the different drawings you can create. I usually make a box or whatever, save it then create a .idw file, then you can just slap in whatever views you want of the part, create some dimensions on it for refrence, print it out and then you have a cut sheet. Lemme hop in Inventor and take some screenshots fo ya! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
thanks! Inventor FTW!!!
I **** hard with a pen/paper... it's just a big square sealed but but I want to give this guy a nice set of blueprints so he doesn't f*ck it up
Once you use it for a little while and get familiar with it you can create almost anything in no time. I'm not gonna lie, it is weird to use at first, but once you figure it out, its amazing. SketchUp is nice because it is very easy to learn how to use, but in the end when you are familiar with both, Inventor offers a lot more.
The two programs are kind of similar in some aspects, but SketchUp is definately easy for someone to use that isn't familiar with it. Inventor is a program created for the Manufaturing and Engineering areas, its more of a professional program. I like it a lot though, but its kind of biast because I plan on going into the Manu/Engineering field.
AcidicDreams
AcidicDreams
Auburn WA
AcidicDreams
